I have been having problems with the hauppauge hd pvr2 and blackscreen.The tech people at hauppauge told me te unit was faulty so i had it replaced but had the same problem. I tried another xbox and the system worked, The tech people in hauppauge now tell me that the voltage output from my xbox hdmi is lower than most xboxes (for some reason)and when the signal splits via the hd pvr its not strong enough for the system to work,contacted xbox and they dont know what im talking about. Help please
If they're correct, it seems to me you should be able to boost the signal with a powered HDMI splitter or amplifier.
blackscreen ? ... on what
Reset console video output to lowest res ... there was also an update which caused this fault, a factory reset should clear this.
With the working console did you try the hdmi cable from it on the suspect console and reverse ... if not then do so to confirm hdmi cable is either defective or not, some are junk. -
with the working console i used all the same cables it worked everytime
Maplin's website has two boxes that look like they are active/amplified HDMI splitters with one input and two outputs, but you should verify that they are not powered by HDMI before you buy. Active/amplified splitters have a power supply that plugs into a household electrical outlet (mains power).
http://www.maplin.co.uk/p/2-way-hdmi-splitter-n08gf
http://www.maplin.co.uk/p/trulink-2-way-hdmi-splitter-n99na
Amazon.co.uk shows additional choices.
Should I get the hdmi/optical cable for my xbox 360 replacement?
By yoda313 in forum Newbie / General discussionsReplies: 0Last Post: 23rd Oct 2009, 16:21 -
xbox 360 hdmi problem (hdmi works on other hdtvs but not mine
By dmiklo in forum Capturing and VCRReplies: 0Last Post: 23rd Sep 2009, 17:51 -
Best HDMI Splitter for Use with Blackmagic Intensity Pro + Xbox 360?
By xmadmardiganx in forum Capturing and VCRReplies: 0Last Post: 22nd Apr 2009, 15:27 -
BlackMagic Intensity + Xbox 360 .. video pass-through using HDMI out??
By norm360 in forum Capturing and VCRReplies: 8Last Post: 22nd Apr 2009, 05:48 -
Possible to output hdmi and optical output on the ps3??
By mrswla in forum DVD & Blu-ray PlayersReplies: 10Last Post: 3rd Feb 2009, 16:17
